For that amount the sky is your limit. Your problem will be the GPU which will be hard to get. That said, pretty much any of them will run any game out there. I run a 3080 and my son runs a 3070, both run everything from COD to World of Warcraft maxed out with ray tracing on. If you are going from your signature pc then I just moved from that generation to a 10600k on an ASUS z490-E. A slightly more expensive option would be the 11x/z590 setup but is the most up to date build. If your ram is B-die then use it in the new system too.
