radeonwin7bug
Disabled
- Aug 17, 2018
This bug all new AMD cards:
- Radeon HD 7XXX;
- Radeon R5, R7, R9 series;
- Radeon RX 400, RX 500 series
with Radeon Driver - from Catalyst v15.7 to Radeon Crimson v18.8.1 (all versions)
NVidia and Intel video cards there are no problems!!! Unfortunately, the problem low 2D performance is present on AMD cards only.
1) Reduced Windows performance and low FPS from the Radeon driver. On the "Standard VGA Graphics Adapter" - no problems.
Programs for the test:
2D Test with source code - Removed
SimpleGLUT with source code - Removed
Radeon driver v15.7.1:
FPS = 4 - 1100 (huge drawdown FPS)
Very large lags when moving windows.
"Standard VGA Graphics Adapter":
FPS = 510-720
There are no lags when you move the window.
2) Increase 2D performance from nothing. If you place the "Radeon Settings" window underneath the spectrum window, so that at least 1mm of the window is visible outside the spectrum window, then the spectrum is accelerated tens of times and the FPS in simpleGLUT rises from 40-60 to 1100-1300. AMD drivers can not determine the resources, which the program requires, and mistakenly sets the video card to minimum performance.
Short video:
- Radeon HD 7XXX;
FPS = 510-720
Short video:
