I'm looking at one of these bad boys. Just wondering what you peeps out there think of it. Is there something better then this out there?? Let me know.... I want it to be 20in. or bigger. I'm new to the LCD world and all I do is play first person shooter type games on my PC.
My current monitor is a (CRT)ViewSonic Graphics Series G810 20in.
This is the one I'm looking at.
Specs
LCD Type 21.3" color TFT active matrix UXGA LCD
Display Area 17.0" (horizontal), 12.8" (vertical); 21.3" diagonal
Optimum Resolution 1600x1200
Brightness 250 nits cd/m2 (typ)
Contrast Ratio 600:1 (typ)
Viewing Angle 170° horizontal, 170° vertical
Response Time 25ms (typ)
Panel Surface Anti-glare
VIDEO INPUT Analog RGB analog (75hms, 0.7/1.0 Vp-p)
Digital DVI-I (TMDS, 100 ohms, or analog capable)
Frequency fh:30~92kHz, fv:50~85Hz
Sync H/V Separated, composite, sync-on-green (TTL)
COMPATIBILITY PC VGA up to 1600 x 1200
Mac®* Power Mac™ G3/G4 up to 1600 X 1200
(*Adapter may be required. Analog adapter available from ViewSonic)
HDTV 480p; 720p
CONNECTOR Analog 15-pin mini D-sub
Digital Digital DVI-I
Power 3-pin plug (CEE22)
POWER Voltage AC 100–240V (universal) 50-60Hz
Consumption 70W (typ)
CONTROLS Basic Power, 1, down, up, 2, soft power
OnView® Auto image adjust, contrast, brightness, input select, color adjust (9300K, 6500K, 5400K, 5000K, user color), information (H/V frequency, resolution, model number, serial number, web site), manual image adjust (H. size, H/V position, fine tune, sharpness, scaling), setup menu (language, resolution notice, input priority, OSD position, OSD timeout, OSD background, OSD pivot),memory recall
OPERATING CONDITIONS Temperature 32–104°F (0–40°C)
Humidity 10–90% (non-condensing)
DIMENSIONS (WxHxD) Physical 476mm (W) x 492mm (H) x 267mm (D) (w/stand) 18.7" x 19.4" x 10.5" (w/stand)
476mm x 369mm x 70mm (w/out stand) 18.7" x 14.5" x 2.8" (w/out stand)
WEIGHT Net 20.5lbs (9.3kgs)(w/stand)
11.5lbs (5.2kgs)(w/out stand)
Gross 26.5lbs (12.0kgs)(w/stand)
13.2lbs (6.0kgs)(w/out stand)
REGULATIONS UL, cUL, FCC-B, CB, CE, ENERGY, NOM, TUV/GS, TUV Ergo, (covers ISO13406-2 and MPR II), TCO‘99, NEMKO, SEMKO, DEMKO, FIMKO, GOST-R, HYGIENIC, SASO, PCBC, VCCI, BSMI,CCC, PSB, C-TICK, TUV-S Hard power switch
POWER MANAGEMENT Meets TCO'99 and ENERGY STAR® standards
WARRANTY Three-year limited warranty on parts, labor and backlight
Specs
HDTV 480p; 720p
