- Jun 5, 2002
- The Netherlands
Hey All,
I was hoping anyone could give me a hand on my problem.
I already looked through all the threads here but didnt find anything... so sry if this has already been asked.
Since a few weeks i have visual problems on my Geforce 2 GTS (Asus v7700; not OC-d; no voltmods etc...)
I did not change anything on the drivers and/or settings. Even did a clean windows-installation but no reveal. Both happens on Win98 and WinXP regardless of drivers (tested others after i had problems...).
Here is what happens:
- z-buffer acting up? Some objects stretched over the screen sometimes.
- Missing textures.
- Textures no colors (looks like it)
- Gabs in maps/levels etc... (like no texture)
Does this indicate
my videocard-memory is too hot / bad?
my GPU is too hot / bad ? (idle it runs around 52 C now)
It has been quite warm the past few days in Holland... and when you look inside my case the warm air from my cpu and chipset is blown (due to the casefan at the top) at the backside of my GF2.
The amount of errors seems random. Sometimes alot and sometimes jus a little. Happens with all games... but only at points where the amount of detail is getting a bit high.
might be important: 3.3V line drops to 3.17V, 5V to 4.7 underload.
Im already getting me a new PSU tomorrow (Enermax 433W) for that.
Could the voltages be a problem or the heat or is just my GF2 at its end?
I did overclock it a few times (220/390 w/o artifacts) but only for a short period to run 3dmark2k1.
My system:
AMD XP 1700+ @ 1,46, ECS K7S5A, 512mb pc133, Terratec Integra128, IBM Deskstar60, Skyhawk 300W PSU
Tnx in advantage for any ideas
- Missing textures.
Does this indicate
My system:
