WARNING! YOU CAN FRY YOUR BOARD IF YOU DO THIS INCORRECTLY OR YOU SLIP WHILE MEASURING THE VMEM VOLTAGE!!
YOU ARE WARNED!!
Ok guys, I am happy to announce that I found the Vmem regulator (HIP6521) for the Iwill P4R533-N!. It is located just below the North/South rimm bank (furthest to the right side of the board) as the board is situated in a vertical ATX case.
I used pin 3 on the dimple side of the regulator. I used a 47K Radio Shack pot with the SMD Grabber.http://www.elexp.com/clp_5243.htm I set mine up where I would turn the pot counterclockwise to lower the resistance which in turn raises the Vmem voltage. You can set the pot up either way for your own preference.
HIP6521 PIC
Here comes the tricky part; measuring the Vmem voltage. There are 2 small Mosfets located in the upper right hand (Northeast corner) of the board. You use the second (South) Mosfet and measure with your VM using the most inboard leg adjacent to the rimm and capacitors. This is where you have to be extremely careful to not slip with the probe (or angle it) by touching the middle snub leg (barely visible) and shorting the Mosfet.
MOSFET PIC
I set mine for 2.92V and the Vcore to 1.93V. The funny thing about my board is that I cannot cold post anything above 148 FSB at 4X setting for the memory in the bios. I can cold post at 156 (max setting) using 3X, but not 4X. To get to 156 FSB, I boot at 148 4X and when I am in Windows, I use CPUCOOL to raise the FSB to 156. It is really slick since I could never get to 156 at 4X. My Sandra Memory is 3950 at 156 FSB. I am using 2-256mb sticks of Kingston PC1066, 32ns.
I ran Sandra burn in for 60+ times using the cpu and memory and then I ran 3d2001se for one hour continous looping with no kickouts, bsod or freezes.
YOU ARE WARNED!!
HIP6521 PIC
MOSFET PIC
