Hopefully this isn't a repeat question, but i am currently overclocking a FX8150 @4.0ghz using the EasyTune6 program from Gigabyte (mobo), and it is very stable, both in Temp (multi programs running 30c, idle in low 20's c) and in Volt 1.28V. I've read in this forum many times not to use the cookie cutter programs to oc, but when i do 4.0ghz manually set at 20x multiplier my voltage according to CPUZ fluctuates from 0.9's - 1.3's even though it runs stable. Can someone please explain if this is an issue and how can i solve it if it is a problem. Thank you.
FX8150 black
Gigabyte GA-990XA-ud3
16gb corsair vengeance LP 1600mhz
Gigabyte radeon 6850 oc
sandisk extreme 120gb ssd
thermaltake water 2.0 performer cooling system = to a H70-H80 or so
FX8150 black
