The Balance CN4949 and the GQ MX-3201 have stikingly same feature on the case, as follows:
~Same location of right side vent
~Same location of CD
~Same rubber pads on LCD
~Apparently same touchpad keys
~Same type hinge and screen latch
~Same placement of power and shortcut buttons
~Same keyboard layout
~Same location for battery
All these are similar to the ECS G320 and the GQ has the same internal features it looks like, All these are somehow by same manufacturer but branded with separate marks...
Here are the links if you want to see for your self
http://www.walmart.com/catalog/prod...ype=19&dept=3944&path=0:3944:3951:4070:188826
http://shop2.outpost.com/product/4197143?site=sr:SEARCH:MAIN_RSLT_PG
http://www.ecs.com.tw/ECSWeb/Products/ProductsDetail.aspx?detailid=314&MenuID=55&LanID=0
