- Jun 12, 2001
- Dorchester UK
Mictlan said:I have added AMDMB.com to the challenge graph.....I'm playing with the settings.....so expect tomorrow the new update of the challenge graph.
We need more power people , the frogz are speeding up.....With all the data I have seen this week they catch us before this year ends......
Mictlan said:Are you using clc in windows? Remeber that you need to do a lot of tweaking in windows so that you can have the fastest setting available. Remeber that:
You need to move your swap file to begging of your HD.
The size of your swap file must be fixed.
Defrag your HD.
Don't use other programs when running SETI (err.....sorry.....but sometimes I have the folowing thought when I'm at home: "shall I play DIablo II?, New better to leave the system there so it can burp another WU faster)
Jon said:CLC is the command-line version of SETI. Has no interface, just a small DOS box that crunches in the background. Makes for considerably better SETI times since it doesn't have the overhead the screen-saver has.
Your WU times probably will be the same whether running Diablo or not because when you run games the SETI client normally goes into an idle state and does not count against you, however, it's no longer crunching either. It is designed by default to only take cycles that are unused, so if a game is using all your CPU cycles, SETI must go idle since it has nothing to crunch with.
Mictlan said:Don't use other programs when running SETI (err.....sorry.....but sometimes I have the folowing thought when I'm at home: "shall I play DIablo II?, New better to leave the system there so it can burp another WU faster)
Mictlan said:
Well, when my cousin is playing Starcraft whil I'm crunching a WU my normal crunching time goes from 6.25 h to 8 or so hours. I have the SETIDriver priority to normal, and sometimes while I'm playing Diablo II and forget to stop SETI I get some slowdown. NO that I play much this days .
wolfsid: If you want to get the command line client going follow this link so you can configure it alright.
