This is my first custom loop. Photo 1 has directional arrows to show flow direction. My logic here was to put a radiator between each component. Not sure if I am missing something or not. Seems like a ton of tubing. What do you think? The loop is filled with distilled water and EK clear concentrate, so it would not cost much to redo the loop.
GPU has excellent temps. 40c max in Heaven with 150 oc to clock and 500 on ram. 1080ti FE.
CPU is not so great. 7700k at 5ghz - 3.3vc - hitting 79c on load. CPU is delidded. This is possible due to the vram cooling and size of block? I was getting similar numbers on a H115i.
