- Sep 9, 2003
- Houston, Texas
Wavemaster Case Mod concept, Tell me what you think...
This is what i plan on doing to my Coolermaster Wavemaster TAC-T01 case. I needed to fit two D-Tek ProCore rads in there with both rads having dual fans/shrouds, and i asked around for some suggestions. Thorilan gave me a good idea at first and this is what was the result of his idea and my crazy conceptions
This is the Coolermaster Wavemaster stock and how it looks brand spanking new.
This is my basic concept model of the same case, cool looking huh?
This is the case with the compartment add-on i will be building for the bottom part of the wavemaster. Keep in mind i didnt include legs or feet for the case in this drawing cause i wanted to the idea and concept across first.
First things first, this picture is all about the bottom of the wavemaster and how i plan to cut it. Thats all that i will be cutting too unless i put a blowhole up top for a 120mm fan. Starting from the back of the case, the slot right there in the very back is for a Eheim 1250 pump, the next two slots are for the ProCores which sould fit nicely.
continued in next post....
