Well i finally got my WC setup all put together and i'm having some problems
My setup contains as follows:
Swiftech Storm
Swiftech MCR220
Swiftech MCP600
7/16in Masterclear
Brass Tline (3x1/2in) with 1/2 tubing from Theisen's on the top.
As of right now at stock i'm getting loads around 65c
i bought the storm and MCP600 here on the forums. I'm thinking that the jets on the storm could be clogged. There is no air is the loop so far as i can tell. i've tilted and shook it every which way and no more air comes out. right now i'm running 100% distilled water until my additives arrive. The block gets hot when i put it under load leaving me to believe there is some sort of flow problem.
Can you guys give me a little advice Thanks
edit: oh the specs of the system are the 1st one in my sig. Firesplitter. Temps are from coretemp.
Mobo - Epox 9npa+ Ultra
CPU - Opteron 165 @ 2.7GHz 1.4v CCB1E 0609 (300x9) | TT Big Typhoon
Memory - 2gig (2x1) OCZ @ DDR450
Video Card - PNY 8800GTS 640MB | Samsung 730b
Hard Drive - Maxtor Diamodmax10 200gig and 300gig | Western Digital 320gig
Case - Cheiftec Dragon Workstation
PSU - Sunbeam NUUO 550wat
Swiftech Storm
Swiftech MCR220
Swiftech MCP600
7/16in Masterclear
