WD RAPTOR (WD1500ADFD) matrix raid or Seagate Barracuda 7200.10 (ST3250620A) m. raid
Hi,
Since I only yesterday found out about intel matrix raid (I real most of the topics regarding it) and since I am upgrading from Opteron 165 to E6750 (from NF4 ultra to P35 chipset) I had some questions regarding it, so I am sure I understood it correctly.
my new CPU shall be C2D E6750 with asus P5K-E WIFI motherboard.
and if understood correctly: regular RAID 0 differs from matrix raid 0 that you can create RAID 0 and RAID 1 with only two physical disks, right?
like in regular raid 0 you would have 150gb raptors as one, but in matrix raid 0 you can have 20gb from each of two of the raptors as RAID 0, and the remaining 140gb from each of the raptors as RAID 1, right?
and how come the burst rate is so ridicuously high (1-2gb/s) in tests posted here, if regular RAID 0 (for example my RAID 0 on DFI ULTRA-D NF4 ULTRA, which had two maxtor 250gb, 16mb cache, 7,200rpm HDDs with NCQ enabled) tests show ~300mb/s?! is it only Matrix Raid? what else does the trick? jumper settings? do you use NCQ (Enables/Disabled?)?
Do I have to remove jumpers from hard drives? You think that I could improve my current results on my DFI ULTRA-D NF4 ULTRA if i remove jumpers from two maxtor HDD's? is the ~300mb/s burst rate score only because it works in sata I mode?
And if raptors wouldnt be an option, which 250gb-320gb (16mb cache, 7200rpm) HDD's would you reccomend as the fastest around, considering that two are used in matrix RAID 0???
WD RE2 ? Seagate Barracuda 7200.10 (ST3250410AS or ST3250620A)?
Does the performance of two 150gb raptors in matrix raid 0 + 1 is so drastically better than for example that of two 250gb ST3250620A in matrix raid 0 + 1 in real life?
Hi,
