hey guys my friends got a problem
"i was OC'ing yetserday, and decided to try upping my volts...
i set the fsb to 243 on my cpu, with stock volts and it was all good, then i kept pushing, making sure itll post, and i got to 253, but i KNEW it would restart on me wen i prime, so i primed, and it restarted, as i thought it would do... so i went into the bios, and changed my CPU volts to 1.55
wen i did that, it wouldnt boot windows... the loading appeared, then it ddnt startup, just froze at the welcome screen, i tried 1.5750 also, but no luck...
wen i went back to 1.5250 it loaded, and again, restarted wen priming...
i thought that increasing the volts should make it more stable... anyone got any idea wats goign on?"
I think its his PSU which is a cheapo 500W psu with little amps on the 12v line.
