- Dec 9, 2003
- Orlando, FL
Most laptop batteries list their capacity in Wh (watt-hours), which is easy to understand because 1 Wh is equivalent to 3600 joules, and if you had a device that used 1 watt using a battery with a capacity of 1 Wh, the device would be powered for 1 hour.
For cell phones it is a little different as most of the batteries are measured in mAh. I'm guessing that would mean that if a device used 1 milliamp using a battery with a capacity of 1 mAh, the device would be powered for 1 hour. But what is the equivalence in Wh and therefore, joules?
