- Jan 15, 2001
- Oregon, Earth
What about the K7V Dragon Plus !
With the VIA KT266 A chipset !
For the Athlon XP1+++ !
http://www.soyousa.com/
I did a comparison with the ASUS A7V266-E
and they use the Very Same Hardware!!!
Kobi
DESCRIPTION
200/266MHz System Interface Speed AMD Socket-A based VIA KT266A ATX Motherboard
Support AMD XP Processor
DDR SDRAM
RAID controller on board
Audio on board, with 6-chanel Hardware Audio
Graphic, Universal AGP Pro slot
Overclocking, setup FSB by 1MHz increment
Network, 10/100 Mbps Ethernet
PROCESSOR
Supports AMD Socket-A type Processor
Including Duron & Athlon & XP CPUs
CHIPSET
VIA KT266A/8233 CE Ver chipsets
Support 200/266 MHz FSB
SYSTEM MEMORY
Three 184-pin DDR SDRAM 2.5V DIMM sockets Support up to 3GB
EXPANSION SLOTS
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal AGP Pro slot (support 1x/2x/4x mode)
On Board Audio Subsystem
On board CMI 8738 Audio chip to provide 6 channels audio solution
Supports optical output & SPDIF output
On Board Ultra I/O CHIP
Two RS-232 Serial Ports (16550 UART compatible)
One Parallel Printer Port (SPP/EPP/ECP mode)
One FDD port (supports 3 mode, 1.2/1.44/2.88 MB FDD)
Provides IrDA port with optional cable for transceiver
Provides 6 USB ports (2 rear, 4 front)
Ultra DMA IDE Ports
Four independent channels for eight IDE devices (two for Raid)
Supports up to PIO mode 5 & UDMA 33/66/100
Two PCI bus mastering ATA E-IDE ports
Boot-Block Flash BIOS
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE/SCSI/CD-ROM/FDD LS120/ZIP
2M byte Flash ROM
Board Dimensions
Four Layer PCB, 30.5cm x 23cm(12" x 9.05")
ATX form factor
Enhanced PC Health Monitoring
On-board voltage monitors for +3.3, +5V, +12V, Vcore,(TBD)
CPU fan speed monitor (TBD)
CPU temperature monitoring through flexible thermal sensor (TBD)
DOUBLE STACK BACK-PANEL I/O CONNECTORS
PS/2 Mini-DIN mouse & keyboard ports
2 USB ports
One RJ45 connector
Two D-Sub 9-pin male serial port
One D-Sub 25-pin female printer port
Audio I/O: LINE-OUT x1, LINE-IN x1, MIC JACK x1
One Game port
FCC CLASS B AND CE EMI REGULATION COMPLIANT
PC 99 COMPLIANT
AND
SOYO Wizard On Hand II Function: CPU FSB Frequency can be setup by 1MHz increment
Embedded Promise IDE RAID chip, provide IDE RAID 0 , 1 function
Supports WOL (Wake On LAN) function to simplify network management
Supports Smart Card Reader connector
Advanced Management Capabilities
* Software power off control, Power-on by keyboard, Power-on by Alarm, Modem Ring On
On board 10/100 Mbps Ethernet function by ICS PHY controller
Suspend to Disk
CPU core voltage & FSB & multiplier could be adjusted via BIOS setup
Supports on-board Hardware Monitoring and includes Hardware Health Utility to streamline your PC system management
Kobi
DESCRIPTION
DDR SDRAM
PROCESSOR
CHIPSET
SYSTEM MEMORY
EXPANSION SLOTS
Ultra DMA IDE Ports
2M byte Flash ROM
Board Dimensions
ATX form factor
2 USB ports
One RJ45 connector
One Game port
PC 99 COMPLIANT
AND
Suspend to Disk
