- Jul 12, 2002
There is no doubt the Alphas are first rate products. I have always considered them the equal of the other top sinks, the Swiftechs and the the Thermalrights. But there is one factor neglected here, that of the fan. The 80mm tornado makes significantly more static air pressure than the 92mm model, and static air pressure is the most important fan parameter for heatsink applications.
I'm not saying the SLK is any better than the Alpha, but I do think the edge demonstrated by the Alpha in your tests stems from the brutal effectiveness of the 80mm tornado for this application. Bigger is not always better. I think with it fitted to both sinks their performance differential would decline to an amount within the margin of error of your trials.
