PunkRawk911 said:
Putting in large 90* bends will seriously hurt flow rates. And air trap/reservoir/t-line are all one in the same, just different versions. You only need to use one. Personally, (what I use) I would grab a piece of 1-2" ID PVC pipe, get an end cap for one end, and a screw type end cap for the other. Dril two holes into the side , screw some barbs in, and you are great to go. make sure you have water flowing in the top barb and out the bottom barb, this allows you to get all of the bubbles out, and also easily add water when you need to.
Here's a link to what I'm talking about. It works perfect for me.
http://www.virtual-hideout.net/guides/pvc_reservoir/index.shtml
As most of you know, air trapped in a watercooling loop is "mulched" into microscopic air bells by the pumps impeller when passing through it. Those microscopic air bells, often more like foam due to the water wetting agents of additives like Water Wetter, Purple Ice, Zerex and other, need some time to go up and reach the water surface.
Your system, which is a more a reservoir than an airtrap (since the complete water flow goes through it), works great with lower flow setups (as in 3/8" or 1/4" loops), but not so good with higher flow systems (1/2" and more).
With high water flow through this type of reservoir the water turbulence is so high that the air is simply trapped into the outlet again without having the time to reach the surface.
This is why most (great looking) german reservoirs like Innovatek's Tank-O-Matic, Fass-O-Matic and other work well with low flow pumps and small tubing as used in european setups, but are almost useless (without modding anyway) when used with high flow pumps and bigger tubing.
This is why, in 2001, I came to the actual concept of my airtrap:
- Incoming water velocity is slowed down in a big (20mm ID) Tee and divided in two flows.
- Biggest part of the flow goes directly down to the outlet by the suction of the pump, but a part goes up in the reservoir part of the airtrap where it creates a very slow vortex before returning into the T again, allowing the microscopic bells to reach the water surface.
At every passage through the Tee therefore a part of the water looses its air.
Starting from a "milky" solution my airtrap clears the water in about an hour, leaving just a layer of foam for a couple of hours on the surface of the water in the reservoir.
CD
