Hello
I'm an average overclocker (no newbie, but not really hardcore as many others here) from Sweden in need of some help with my current system.
My problem is that I don't seem to be able to push my system further and I can't really tell what is holding me back: is it my PSU, the motherboard or bad chips? (GPU/CPU)
Current system is:
AMD Phenom II X6 1090t OC @ 3.9GHz with Noctua NH-U9B SE2 -air cooler
Gigabyte GA-970A-D3
Corsair XMS3 Vengeance 8GB 1600MHz
Asus HD6970 2GB DirectCU II OC 930MHz clock/1425MHz mem - OCZ ModXStream 700W
My chassis has 4x 120mm fans (2 out/2in) and 2x 140mm fans (1 out/1 in) so my airflow is pretty good.
I also have fan controller which tells me the temps in various areas of my chassis and I'm pretty happy with how it is right now.
The CPU overclock:
Currently I'm running at a 19,5x multiplier with my reference clock set at stock speed of 200MHz, which gives me a little over 3.9 GHz (stock speed is 3.2GHz). My core voltage is set to 1.5 volts - default value there is 1.325 (I think, can't remember).
My CPU/NB is on a 14x multiplier giving me 2800MHz. Stock there is 2000MHz @ 10x multi.
CPU/NB voltage is at 1.25v
HT is at factory settings (10x multi which equals 2000MHz)
System is stable with the above setup.
CPU OC problem:
I don't seem to be able to even touch 4GHz - even though I know that this is a realistic goals (I've seen PLENTY of overclocks reaching 4GHz at or around 1.4v). I've tried a 20x multiplier with more voltage but that won't do the trick, and I don't want to go over 1.55 volts as AMD recommends no more than 1.55v in vcore. I've also tried combining a higher reference clock speed with a lower multiplier - but that haven't worked either. 4GHz is simply not possible @ 1.55 volts despite how I overclock (refclock, multiplier or both).
My CPU/NB also doesn't seem to be able to climb higher than 2900 (gives instability near 2950) despite increases on the voltage.
Temperature is not holding me back at all - at least not on the CPU. However, I do not have any custom cooler on the NB chip itself on the motherboard.
The gcard overclock:
Stock voltage: 1.175 volts, upped to .025 to 1.2v
Factory OC is 890MHz core and 1375MHz memory, which I've succesfully OC'd (stable) to 930MHz/1425MHz.
Gcard OC problem: I can't up the core any more. I can reach 950MHz and pass my benchmarks/stress tests - but once I play Battlefield 3 at that speeds and my entire system (CPU, GPU and memories) gets workload, my display driver crashes along with the game and I have to cut back to 930.
The same goes for the VRAM. I can up it independently to 1500MHz and pass my benchmarks/stress tests - but once it comes to actual gameplay (BF3) the display driver crashes and drags the game along with it.
My thoughts:
I started by OC:ing the CPU by first finding out my max values independently (keeping everything at stock and just OC:ing one part of the system at a time). I got frustrated hearing about how people could reach 4GHz with worse coolers than I have, and with much lower voltages (best chips seem to be able to do this at 1.375v - most at 1.4 to 1.45). At this time I thought that I simply had a bad chip and I just shrugged it off and moved on to OC other parts of my system.
When OCing the graphics card I had a bit of a problem because some overclocks worked fine in Furmark while failing in 3d mark 11. I could push my graphics to I think it was 975MHz core and still pass Furmark but at some not-so-great GPU temperatures of around 85 degrees C. So yeah, at the start I played around a lot at 960-975 - even trying to push it to 1GHz. But with time I cut down more and more as I saw that not even an overclock of 60MHz (950MHz) would pass in 3d mark 11 or they would crash my display driver when playing BF3.
Now after OCing the CPU, CPU/NB, GPU and graphics memory, I'm a bit confused because I'm unsure of what exactly is holding me back. It could be my PSU? The gcard I have recommends a minimum of a 700W PSU according to the manual. Or it could be that my budget mobo just doesn't cut it for overclocking. Or it could be that I've been unlucky with both the CPU and GPU chips. But which one of these is the most probable cause do you think?
Another possibility is that my VRM is getting overheated. But I haven't really been able to find any info about that in regards to my mobo: I don't really know what a high temperature is, and don't even know which of the TMPIN0 to TMPIN2 -meters is the VRM in HWmonitor (as these meters/labels are different from mobo to mobo).
What is your thoughts on this?
Also, for clearifications: TEMPERATURES is not my problem. The only time I get alarming temps is when I drag the GPU voltage up too much and run Furmark (which is like an angry army drill sergeant on your GPU: nothing in the world will push it harder).
Current system is:
Gigabyte GA-970A-D3
The CPU overclock:
CPU OC problem:
My thoughts:
