I can't find any info on your specific GPU. I had a HD7970 that needed pad replacement and was able to find info on it. Looking at the 7850 and 7970 for comparisons it looks like all the memory ICs use .5mm and the VRM/Mosfets vary by card and use either .5mm or 1mm. It would be best for you to get a sheet of each. It's not too expensive and that way you have everything on hand when you're ready. Here are a couple reference sheets I could find.
https://www.ekwb.com/shop/EK-IM/EK-IM-3831109856239.pdf
https://www.ekwb.com/shop/EK-IM/EK-IM-3831109856154.pdf
https://www.ekwb.com/shop/EK-IM/EK-IM-3831109856376.pdf
Also, if you look at the 6xxx series cards, some used 1.5mm thick pads. I did not find that to be the case for the 7xxx series cards, but that does not mean yours is out of the question.
Performance PCs is probably your best place to get pads. Back when I did this Fujipoly was the highest-rated. I have no idea who is the best today but would assume any major brand would meet their spec'd W/mk.
