So it's settled then.
I will buy those Gskill's on Tuesday!
Instant Savings end 2014-06-15.
Will do!Just enter the Ram timings in the Bios by hand, and see how it goes, then come back on here if you need any help!
AJ.
Except that.....
Looking forward to see what you get.
Canadian G.Skill knockoff sticks? One of the L's in G.Skill is an uppercase i. lol
Woot, glad it's going well! Just make sure to run Memtest on the sticks to make sure no errors.
Hey Silver,
You need to enter by hand in the Bios, The TRAS is 24, also TRC should be 33 you will need to enter these as well!!
Also when you have entered those just try that out, then try changing the COMMAND RATE to 1T, and see how that will work!!
AJ.
I've waited until now so as not to hijack Silver's thread, but I have a question concerning 8GB vs 16GB. Not long ago Tom's Hardware posted an article speculating an SSD may last longer with 16GB since the extra memory would reduce the number of times the SSD would be accessed. Before the article came out, I bought 16GB RAM because I'd been thinking along the same lines. I have no idea if the "theory" is valid or not, but a few extra bucks spent for additional "insurance" seems logical; what I really want is to be able to buy a new SSD when it's an option and not an "emergency". I've followed Tech Report's ongoing "longevity" tests, but the amount of RAM was not, that I saw, specifically addressed.
Some new games are already using more than 8GB. Even older like Civilization V on large map could use ( with system ) up to 9GB.
Hey Silver,
AJ.
@wingman99
Well, if you have a huge map, it'll use up the RAM, then spill over into the lovely page file.
Doesn't matter if the game is only 8Gb, it can use up more RAM than that.
How does Civilization V use 9GB the hole game on the HDD is only 8GB
These Are the Civilization V System Requirements
Recommended System Requirements
Operating System: Windows® Vista SP2/ Windows® 7
Processor: 1.8 GHz Quad Core CPU
Memory: 4 GB RAM
Hard Disk Space: 8 GB Free
DVD-ROM Drive: Required for disc-based installation
Video: 512 MB ATI 4800 series or better, 512 MB nVidia 9800 series or better
Sound: DirectX 9.0c-compatible sound card
DirectX®: DirectX® version 11
