- May 1, 2003
- Seattle
wireless will add 2-3msdaunsociable said:
RJARRRPCGP said:Disappointingly, you got 207 ms for the latency. That's high for cable and DSL. Even my 56k modem can go lower than that. Cable and DSL usually is no higher than 90 ms.
That's actually enough to be thinking about getting a different ISP, IMO.
Appears to be routing problems. But may be temporary.
I'm just concerned, because that was for only 100 miles.
I would understand somewhat if the test server was located in the pacific zone.
[root@smoothwall root]# ping ocforums.com
PING ocforums.com (69.20.37.110) from 24.152.252.210 : 56(84) bytes of data.
64 bytes from 69.20.37.110: icmp_seq=1 ttl=111 time=21.7 ms
64 bytes from 69.20.37.110: icmp_seq=2 ttl=111 time=19.8 ms
64 bytes from 69.20.37.110: icmp_seq=3 ttl=111 time=21.9 ms
64 bytes from 69.20.37.110: icmp_seq=4 ttl=111 time=22.0 ms
64 bytes from 69.20.37.110: icmp_seq=5 ttl=111 time=21.5 ms
64 bytes from 69.20.37.110: icmp_seq=6 ttl=111 time=21.2 ms
64 bytes from 69.20.37.110: icmp_seq=7 ttl=111 time=22.8 ms
64 bytes from 69.20.37.110: icmp_seq=8 ttl=111 time=21.0 ms
64 bytes from 69.20.37.110: icmp_seq=9 ttl=111 time=21.9 ms
64 bytes from 69.20.37.110: icmp_seq=10 ttl=111 time=41.5 ms
--- ocforums.com ping statistics ---
10 packets transmitted, 10 received, 0% loss, time 9096ms
rtt min/avg/max/mdev = 19.852/23.593/41.587/6.046 ms
bAzZaMish said:some of you people don't know how lucky you are...
and no this is not dial-up...
