- Nov 19, 2007
- San Jose, CA
Hi guys, I have Klipsch THX speakers for my computer. I plugged them in and one of the speakers don't work. So I tested to see if the speaker itself was screwed but it turns out just one of the wires that has a 5mm jack, seems to not be working.
The way the wire works is, the 1 end of it (it has a + and - end) is just cut off and you clip in the stripped exposed copper wire into the sub woofer. Each speaker has 2 of these +/- wires.
Well I'm pretty sure I can find that wire, I can't seem to find one that already has the 5mm jack on it so i can plug it into my monitor.
ANy ideas where I can find these wires? I tried FRY's and found nothing and they usually have everything. Also does anyone even know what these wires are called?
Thanks
EDIT: these are what my speakers look like (mine are about 4 years old now) but look exactly like these.
https://www.klipsch.com/na-en/products/promedia-2-1-overview/
The user guide says:
So the end of it is called a DIN plug, and the end that connects to the speaker is called a tinned wire lead. They sound like just standard audio cables, but I can't find any that already have the ends, its just wire with no ends to connect to the speakers. Also the end of the wires that connect to the subwoofer seem to be coated with some other material than just the copper wire.
Thanks
Connect the DIN plug to the subwoofer from the control satellite preamp.
3. Connect the speakers by inserting the tinned wire leads into the subwoofer and the back of the
satellites. The solid black wire (-) connects to the black spring clips; the black wire with white
dashes (+) to the red spring clips.
