W wun911 Member Joined Jul 3, 2006 Location Australia Nov 2, 2006 #1 Where do I get one of these from except I want it black in colour not silver.
ctrl_alt_del_ Member Joined Dec 15, 2004 Location Clermont, Florida Nov 11, 2006 #2 I believe these are Lian Li cd covers - you might get luck and check performance-pcs.com on their Lian Li parts section. Good Luck!
MVC Member Joined Dec 20, 2004 Location Hell's Kitchen, NYC Nov 16, 2006 #3 If it is a Lian Li, try SilverPCs. They've probably got the best selection of replacement Lian Li parts. If it isn't a Lian Li, can you say what it is?
HarlanC Member Joined Oct 2, 2006 Nov 17, 2006 #4 Havent you already posted this? Its an older cd rom right?
Sleepy_Steve Member Joined Dec 3, 2004 Location VT... or MD Nov 17, 2006 #5 Yeah... he did. http://www.ocforums.com/showthread.php?t=484506 Its still on the first page too. In the same section. In fact ITS THE SAME EXACT POST!!!! .... tisk tisk.
Captain Slug Helpful Senior Member Joined May 23, 2001 Location Asteroid B-612 Nov 17, 2006 #6 http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=257&products_id=437 Now quit asking. Buying a cover ends up being 1/3rd of the cost of a new drive that would have the correct faceplate color.
HarlanC Member Joined Oct 2, 2006 Nov 17, 2006 #7 Captain slug has spoken! and I will say it again...just spray paint the face plate black. Pretty much the only way you'll get an exact fit, unless you get lucky.
