- Jan 19, 2003
why wouldn't it be thick enough?
A backplaned sink! That's a good idea. but I think it'd need active cooling to prevent the parts that get warm from overheating by sharing the same sink with the components that truely get hot.. Maybe a large backplaned waterblock, with the pathway snaking back and forth across the whole block's interior.Veland said:A bit on the side of the topic, but why don't somebode make a brand new MB format. Lets call it.. S-ATX. This is the plan:
- Have every heat producing component on the back of the MB, at the same height
- Have alle the connections and ports on the other side.
- As this means less stuff on the front side, have the AGP/PCI slots over the CPU/NB/SB and stuff.
Why?
- Shorter paths so more stable
- Attach the MB to a large HS (backplane=HS) for quiet cooling
- Small size!
But this would mean several millions of design work, even more layers so expensive PCB (but smaller!) and a new format needing new cases..
squeakygeek said:
haha, I was referring to star882, and his "britneys". I should have been more clear.
vonkaar said:Or, you could seperate various 'hot' components with smaller sinks. P2/3 Xeon heatsinks would be great for that... I have a bunch of those, and they are fairly cheap anyway... usually 5"x5" or so. The idea is definitely coo... pun... dangit... it's very nice.
I would think that using multiple heatsinks would cause that problem of the heat radiating to the others. whereas one large on would have no placce to send the heat to other than the surrounding air. Add a few low cfm low dbA fans just for circulation (if at all) and it should work great. Awesome idea btw, Velandvonkaar said:That was in response to the post directly above it. Eobard mentioned that keeping all of the heatsources on a single heatsink could be counter-productive. If you kept the whole underside of the motherboard covered in 3 large heatsinks, and they were joined up together loosely, like with a rubber gasket or such, the heat wouldn't radiate to each other so much as with a single heatsink. I'm saying... keep with the 'whole backplane-heatsink' idea, just use say... 4 smaller heatsinks instead of one huge one.
marcus90509 said:uh i found what's the britney (star) cpu
as i know it's an opteron socket 940 (i think) but can be also socket 7xx
CrashOveride said:
Um... I don't see how you figure using one would help more... Metals are a better heat conductor than air (in most cases, esp the case of a HS), so heat will move more easily via the HS to other parts than it will via air... try this... put one HS on a cooking burner or hold a lighter under it and then put another HS next to it but away form the Heat source (if you are using a lighter make sure the air doesnt go by the other one), then try it while holding the HS a short distance away. I gaurntee that if you do this correctly the second HS will heat up MUCH faster when its touching.
pik4chu said:
yes but if you sperate the HS's it creates gaps in the board that are not in direct contact with the HS, and therefore heating up more or even beyond what they should. so having one single piece would cover the entire board completely and then it would not be uneven, even if heat is spread throughout the heatsink before disipating. Which is the point of a fan.
CrashOveride said:
Um.. the components would probably be sperated like they are now just all on the same levle, there would be gaps wher eyou could have a space btwn HSs... But you see some components have a lower max temp than others, like the CPU/NB and mosfets, mosfets can get MUCH MUCH more hot than a CPU and still function perfectly. If you used the same HS the average tempurature of the HS MIGHT be hotter than some components can take, while having seperate ones that are connected by a thermal capaciter (so its still one piece but not solid metal) would pretty much eleminate this.
pik4chu said:
then whats the point of having lage heatsinks?
You're right. silly me. but then why not just get high HS (small base but long fins etc) and put on on each little component seperatly and have two low dba high cfm fans blowing across all of it or just in opewn air for complete passive cooling of every heated component?
CrashOveride said:
Well you could have HS's that are larger than you could put on there now ijust by redesigning it... and you would be able to combine thing in general like, NB/CPU, Mosfets, and pretty much everying else. So it woul dbe like 3 BIG HS's, probably with a slightly thicker base so the heat can easily travle to all the fins (thiner would restric the flow of heat too much for the extra area of the HS to take effect, then just have 2 120mm fans blow on it... and the AGP slot right next to it so that it gets air from teh fans as well (video card that is) and the memory bten the video and the big HS so it too gets air from there and bam, very quite, cool system.
pik4chu said:
you might even add a 4th sink just for the video and RAM and use the same cooling.. orrrrrrrrrr
You could use heatpipes from the MOSFETS and other smaller components and run it straight to the side panel of the case, which would be a heatsink. then use the other larger ones for the Vid/RAM and NB/CPU and other miscellany or some varioation of that. to have heatpipes for everything but the major heat generators.. CPU/NB being first with Vid/RAM close behind (depending on system config). either way.. it seems its better to have seperate sinks per type of component with minor air circulation to be the best solution for this kind of cooling (at or near fanless) wonder when Kunaak will get on and get us back on track lol.
