- Jan 24, 2011
- Zebulon, North Carolina
where might i find a place to get a rack mount?
It might not even be called a Rack Mount, basiclly people put there motherboards on it along with GPUs and the PSU sits under the rack, typically review sites use them.
Let me see if i can find an example. they might be called workbenches or test benches, either way google is giving me a bunch of unrelated stuff.
I can't really find anything because i'm not sure what they're called, but anyway my plan was to set up a EVGA Classified board with 4x 6970's in crossfirex, so i need to find one large enough for that, and that would fit 2 - 1200 watt PSU's under it comfortably, eventually i will move those 6970's into a different rig when i can hunt down some 6990's in time, or whenever the 7000's dual GPU's come around. There is no way i am going to try to cram all of this into a case.
here we go, it's something along these lines, a XL ATX size, $170 seems a bit pricey though, i'm open for suggestions http://www.highspeedpc.com/Merchant2/merchant.mv?Screen=CTGY&Category_Code=TopDeckXL
