@EarthDog, the server had a hiccup ...
I see it like:
DDR3 -> DDR4-> DDR5
1333 -> 2133 -> 4800 <-- initial/SPD clock
2133 -> 3600 -> 6400 <-- gaming/recommended specs after 1-2 years
2800 -> 5000 -> 8000 <-- max clock available in stores
The expected max clock for DDR5 is 8000, but we will probably see a bit more. The expected max clock for DDR3 was 2600, for DDR4 was 4800. In most cases, we could see some more.
The current generation can't make more than 6000-6400 on higher series 4-slot motherboards and top OC motherboards (count it like 4 models only) can make 6800+.
The current DDR5 (at least Samsung and Hynix) can make 7000+ but at high voltages compared to the JEDEC values. However, motherboards are highly limiting the max clock, so I guess that the next-gen Intel or AMD may change the way how we see DDR5. The next-gen will be later this year.
It's always like release -> fine-tuning and optimizations -> higher capacity but not necessarily higher frequencies -> end of the generation
- DDR3 reached optimal clock after about a year with PSC and Elpida IC, after that were higher capacity options like Samsung/Hynix.
- DDR4 reached optimal clock with Samsung B (so 2nd generation with already a bit higher capacity) which was supposed to be dead for 2 years+ already but the high demand caused the production to be renewed. There are newer IC that can make higher frequency and capacity but memory controllers and motherboards can't handle it.
- DDR5 already started at a wide range of frequencies from 4000 to 6000+, so it's like it skipped one generation looking at early DDR5 plans. Clocks can go higher, motherboards can't handle it. We will see 6800 kits in stores soon but anything above that is already delayed because of problems with compatible platforms. There are 7000 kits on some motherboards' QVL, but really it's so close to the edge of stability that I doubt anyone will release it soon and guarantee compatibility with any available motherboard. What you see on QVL is not always a retail product. There are no retail 6800+ kits yet, but some motherboard brands have them on QVL. Actually, most memory kits from QVL were never released in retail, and even if the PN matches then often the IC is different like ASUS has most ADATA and G.Skill kits with Hynix IC when everything in stores was with Samsung IC. Hynix kits arrived with a bit different PNs.
