Where is the water go?
follow up with update. Last couple of months I noticed I still loosing water a little and its gotten worse. Upon inspection and found my dual pump reservoir, the bottom pump one of the screw leaking water. So I hot glued all the screws. After two days. My reservoir still full. Finally fixed the leaks.
Glad it was a relatively easy find and and fix!
Make sure to give a look and tighten anything loose. This way you'll have less chance to lose water. :)
