pictures
Beginner: I ordered them from hosfelt.com as crimedog suggested.
Now for the pics
VMOD1
comments: This gives an overview of the layout at a pretty high resolution. As you can see, I went a 'bit' overboard on conformal coating but I figured it was better to be safe than sorry in this case as my wires do have quite a bit of exposed copper on each end. I plan on cutting some shrink wrap in half and sealing off the points coming off the potentiometers sometime. The reason one is upside down is because when I realized I had them on in the wrong configuration I desoldered them and then put one on 'backwards', by this time I was fairly frustrated and didn't want to deal with it anymore. I also failed to cut my wires to the shortest possible length but the messiness doesn't bother me so I don't think I'll be redoing it.
VMOD2
comments: This is a close up of the vgpu mod area. As you can see I had some exposed wire where the iron briefly touched it. This actually happened when I was soldering the point, not the capacitor. I just put a good coat of conformal coating below the wire in the affected area and let it dry for a bit and then covered the bare wire with conformal coating, so it is sufficiently insulated. The point also has a considerable amount of exposed wire which was due to the insulation shrinking away while I was trying to solder the point. Again I just made liberal use of conformal coating before tacking the wire down. This was the hardest point to solder of all of them because there is a lot of connections which could easily be bridged within a few millimetres
VMOD3
comments: This was the last point I soldered and I consider it the best. My criterion for an 'acceptable' joint was that I should be able to lift the card up from the joint without it breaking. I think I used to much solder but I wasn't too keen on messing with it anymore.
AAR (After Action Review): Well, it works, but I think I learned a lot of lessons which would enable me to do a much better job next time around. I really should have practiced on some spare dead disk drives before I started to do the mod at least but I'm a rather impatient person and I've had some experience soldering together much larger objects (although I've never been good at that either). I don't think I would run the trimmers to the edge of the board if I did it again. It would be much easier to just tack them down in place and I think I could make it look cleaner. Of course, having a screwdriver near exposed conductors could be bad news if you slipped off the trimmer adjustment knob. In any event I'm extremely satisfied with the result and can't wait until I get my 'new' memory modules to start tweaking it some more.
dark days have fallen over the memory socket.
edit: Revivalist: you can see how i've done the fan, I've tried both ways and I believe it works best when it is pulling air off the vreg rather than pushing air onto it. It is actually pushing air onto it in this configuration and I plan on flipping it back over. I briefly considered pushing air across the board like the reference cooler does but I doubt it would yield any better results on the memory and my case has quite a bit of airflow in it. I don't have it on their very tight because I have a feeling it would place a lot of stress on the pcb which would be very not good. The fan is plugged into one of my motherboards headers and I believe I could adjust it if needed but I just leave it at full speed since the 120x38mm 115 cfm panaflos drown out all the other noise anyway.
