- Apr 3, 2013
Sapphire SC-S7790OC Dual-X Overclocked
http://www.sapphiretech.com/presentation/product/?cid=1&gid=3&sgid=1159&pid=1876&lid=1
or
PowerColor AX6950
http://www.powercolor.com/Global/products_features.asp?id=313
The price difference between the two cards are just below $3.00 (Three dollars). The AX 6950 being $3.00 more than that of the HD 7790.
The differences I've picked up so far are that the HD 7790 is 128bit and has 1GB of memory whereas the HD 6950 is 256bit and has 2GB of memory. I know this will make a difference when playing games like Max Payne 3 and The Witcher II where the more features you enable, the more memory is required to play.
According to GPUBoss the performance difference between the two cards are miniscule enough for them not to declare a winner.
I'll be running either card at 1360 x 768 resolution.
The HD 7790 is PCI-E 3.0 whereas the HD 6950 is PCI-E 2.1 which doesn't really matter even though my motherboard supports a PCI-E 3.0 GPU, my CPU does not (Intel Core i7-2600).
I'd like to hear from you guys which is better.
Thanks in advance.
or
PowerColor AX6950
Thanks in advance.
