- Aug 27, 2003
- Mississauga, Ontario
I couldn't believe what I got in the mail today, two checks from two of my old jobs, one for just over 3G's and the other for 1.5Gs. Naturally, as you can see from my sig, it's time for and upgrade.
I will spend about $800 on a laptop, but also want a gaming desktop that will compliment the one I have now (which does the job, but hell, we all always want better).
I need some opinions.
I am going AMD, there is no debate about that.
However, after reading about 790FX and the new 890FX, I just don't see the point? What is the point of paying extra for the latter? The GB 790FX even has 3.0 USB ports and SATA 6GB/s ports, so I don't even know if there is any difference at all.
I will be running one video card, so no need for many x16 slots etc, no crossfire.
I will be using a 6 core chip, haven't decided yet, a good budget one that will overclock one, I was thinking of the 1055T but I may get the 1090T if you convince me it's the better choice.
Is the above mentioned Gigabyte the best choice? Similar Asus is at least 20% pricier so that's out, but I also don't want crap, so GB seems to be the best bang for the money, what you think?
Then I will run 4x2GB RAM, please recommend some for me, I prefer not to screw with latencies so I want to O/C it only to the point that it is stable with stock low latencies, I will not sacrifice latencies for a few MhZ (unless you convince me otherwise, again). Of course if I get the 1055T, that may be tough to do as it's locked so it will automatically screw around with my mem clock, and it may force me to relax the timings in order to stay where I'm comfortable with the 6core speed (I'm shooting for 3.5GHz everyday use, nothing crazy).
Basically, I just need an opinion on mobo/cpu/ram combo, with the "musts" that I mentioned above (6 core AMD chip, good mobo that has at least a couple 3.0 USB ports and SATA3 connectors and be of course overclocker friendly (I think most are now, I wonder what happened to DFI, they rocked in the dual core days, but I'm afraid to get the AM3 790/890FC one cuz of some scary reviews even tho it has an excellent price point))
The rest doesn't matter, I will throw in an SSD OS drive and 2 2TB storage drives, a good ATI video card that can play the latest games at 1920x1200 smoothly, and since my 3870 plays most games at that res already, albeit without AA or AF, I don't see why I would ever need crossfire or even a top of the line card, I'm thinking a 5700 series (top one), but I may get the 5800 if I can afford it.
PSU and case are taken care of, as are all the peripherals, so the above is all I need.
Oh, and a good aftermarket heatsink/fan combo for the chip, whatever I end up getting, if it is even necessary (I heard stock is pretty good now), ideas would be appreciated.
If I missed anything, please let me know. Remember there is a 40% price diff in 790fx and 890fx and I can't find any diff in specs, and also a 40% price diff between the 1055t and 1090t and again, not sure if that is worth it.
Thank you very much, I hope I didn't bore you with the long post, but I really NEED to make a right decision here because this is going to be with me for a while, I need it to be right.
