iLLestOne said:What if you put a fan on the hs, AND on the other side pushing in the air? I was thinking about doing this, but I was going to cut a whole in the side of my case DIRECTLY over the cpu hs. So the duct would only go like 4" straight to the cpu, so no rough edges. Wouldn't this work better?
It's exactly what I was considering too. It's a short vent, could be done with PVC for flow efficiency, and would be inexpensive. The only problem is that I don't want to cut on my Lian Li's side window I was thinking of building another computer just so I could do this mod and check the cooling ability vs noise level. It would be quite interesting, and with the right fan (was thinking Tornado), it could replace 2-3 exising intake fans. I would consider adding 2 exhaust fans though, so the net effect is increased airflow
