- Oct 8, 2003
- North Attleboro, MA
You toggle it in the driver settings (right-click on the desktop, choose "Properties", and keep drilling into the "Advanced" menus until you get to the ATI settings pages) -- either you can set it to "Application", in which case games that support it should have an option to turn it on/off, or you can manually set it to whatever level you want and it will always be on. Also note that you can set it separately for OpenGL (Quake3, RTCW, etc.) and D3D (UT2K3, HL/CS, most other games). I think the 9600Pro should run alright with it at 4xAA/4-8xAF in most games, unless you're pushing the resolution way up. Give it a shot and see what works best for you.
And it only affects 3D mode. It doesn't make sense to try to anti-alias your desktop, as it isn't being "rendered" in the same way and so any aliasing is inherent to the image.
