I just wanted to know if any one knew if my mobo will be able to support 2 4890's in CrossFire?
my mobo is on my sig but here all full specs.
Model
Brand EVGA
Model 122-CK-NF67-T1
Supported CPU
CPU Socket Type LGA 775
CPU Type Core 2 Quad / Core 2 Extreme / Core 2 Duo / Pentiu
FSB 1333/1066MHz
Supported CPU Technologies Hyper-Threading Technology
Chipsets
North Bridge NVIDIA nForce 680i LT SLI
Memory
Number of Memory Slots 4×240pin
Memory Standard DDR2 800
Maximum Memory Supported 8GB
Channel Supported Dual Channel
Expansion Slots
PCI Express x16 2
PCI Express x1 2
PCI Slots 2
Storage Devices
PATA 1 x ATA100 2 Dev. Max
SATA 3Gb/s 6
SATA RAID 0/1/0+1
Onboard Video
Onboard Video Chipset None
Onboard Audio
Audio Channels 8 Channels
Onboard LAN
Max LAN Speed 10/100/1000Mbps
Rear Panel Ports
PS/2 2
USB 4 x USB 2.0
IEEE 1394 1 x IEEE 1394a
S/PDIF Out 1 x Optical
Audio Ports 6 Ports
Physical Spec
Form Factor ATX
Dimensions 12.0" x 9.6"
Windows Vista Certified for Windows Vista
Power Pin 24 Pin
Packaging
Package Contents 122-CK-NF67-T1
Driver Disk
Rear I/O Panel Shield
IDE/PATA Cable
FDD Cable
SATA Cable
4-pin to SATA Power Cable
SLI Bridge
I'm gonna need a new PSU i know.
Model
Brand EVGA
Supported CPU
FSB 1333/1066MHz
Chipsets
Memory
Expansion Slots
PCI Express x16 2
PCI Express x1 2
PCI Slots 2
Storage Devices
SATA 3Gb/s 6
SATA RAID 0/1/0+1
Onboard Video
Onboard Audio
Onboard LAN
Rear Panel Ports
PS/2 2
USB 4 x USB 2.0
Audio Ports 6 Ports
Physical Spec
Form Factor ATX
Power Pin 24 Pin
Packaging
Driver Disk
IDE/PATA Cable
FDD Cable
SATA Cable
SLI Bridge
