Just noticing my htpc (A4 6300) runs pretty warm. Would slapping a cheap-o gpu take some load off the APU and allow it to run cooler? Seems like it would work in my head, but I havent seen any direct practical results from this in my googling.
According to an AMD engineer who frequents a forum no. He said that you actually generate more heat by the graphics being off die. Now the cpu and graphic card have to communicate through a bus which generates more heat. I probably did a very poor job explaining what he said.
Interesting. I'll grab a cheapo graphics card and play with this. < Nothing like a good experiment for sure.
RGone - makes sense. The heat issue is purely the cpu running really really hot. Idles around 45-50c, and streaming data brings thst around 60c. Not concerned with noise, it just seems really hot for not doing much. < Well that does seem warm if you are speaking of the package/core temp and not the socket/cpu temp. Never know when someone posts only the single temp when we are used to seeing HWMonitor so much for discrete FX processors.
TIM was reapplied twice, no change. < Gotcha.
I am also aware a cpu cooler will work, just not much fits Ina 6" wide case is all. Merely a discussion point for these things. Yes I hear you. Often looking at one thing gets me rubbing shoulders with other things. I am looking now at OpenCL 3.0 specs and compiling for windows. Too bad am such an ole faht withouut programming skills. Hehehe.
