- Apr 22, 2002
- Austin, Texas
Would my cpu be in danger of burning up with a 80mm Sunon 31 CFM, 2300 RPM, 25 dba fan on a Thermalright AX-7 with Arctic Silver 3? I checked the temp on my first boot which is 41 degrees then after installing Windows I turned the computer off. I wanted to test everything first so the mobo was outside of the case when I checked the temp. I rebooted just to check if I can get back to Windows and no problems occured. I then disassembled everything because I needed to mod the case a little. My dad said he can make a 80mm to 120mm adapter out of sheetmetal so I can use a Papst 120mm, 53.3 CFM, 1600RPM, 26 dba fan on the heatsink. It will be a week though until the fan comes in and the adapter is ready. I have nothing to do (I'm on vacation ) so I want to start loading stuff onto the computer but don't know if I should wait for everything to be ready first. I don't see anyone here using a fan as weak as mine so I'm concerned that the Sunon is not strong enough to run the computer for a week. This is my first build so I'm new at this. I'm concerned about noise, that's why my fans are weak. Thanks!
AMD Duron 1GHZ + Thermalright AX-7 + Sunon 2300RPM, 31CFM
Abit KR7A-Raid Mobo
Western Digital 40GB, 7200RPM, ATA100
ATI Radeon 8500 OEM
Lite-on 32x CDRW
Antec 400w PSU
Case cooling: 2 Dynatron 80mm 28 CFM, RPM unknown, 24 dba (front intake), 1 Sunon 2300RPM, 31CFM, 25 dba (back exhaust), holes cut for unobstructed airflow.
Abit KR7A-Raid Mobo
ATI Radeon 8500 OEM
Lite-on 32x CDRW
Antec 400w PSU
