Will this work??
iceemann44
Hello everyone, my first post!
I see some people are knowledgeable about computers around here. I'm building my first gaming rig, and wanted to make sure everything is compatible. Here goes nothing..
PROCESSOR + MB + GRAPHICS CARD
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.259503
$415 (20 MIR)
RAM
Kingston ValueRAM 4GB DDR3 SDRAM Memory Module - KVR1333D3K2/4GR
http://www.buy.com/prod/kingston-4g...10600-desktop-memory/q/loc/101/210809564.html
$64.95
HDD
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive - OEM
http://forums.slickdeals.net/showthread.php?threadid=1550077
$76.49 Price: 84.99 + free shipping - 10% discount code (EMCHDD10B) = $76.49
CASE
RAIDMAX SMILODON Extreme Black ATX-612WEB 1.0mm SECC Steel ATX Mid Tower Foldout MB Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811156078
$59.99
POWER SUPPLY
CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Produ..._-NA&Item=N82E16817139008&Tpk=N82E16817139008
$29.99
CD/DVD BURNER
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 48X CD-R 32X CD-RW 2MB Cache SATA DVD Burner with LightScribe LightScribe Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118032
$33.99
GRAND TOTAL = $680.41!!!
Sooo I've got everything minus a monitor, keyboard, mouse, and speakers which I can hook up. What do you guys think?
Id personally go with more PSU, but thats me. 400watt should be enough for your setup, but that 400watts is rated at peak, not 24/7. Corsairs are great PSU's, but PSU is something you dont skimp on, ever. Id go with a 500watt for your setup personally.'
Also, if you can spend a few more dollars, Id go with a WD Black drive over the Seagate, but thats me. Also, spend $5 more and get this ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227346 Its CAS7 compared to CAS9 but its also 1066, so you decide. OR spend a bit more and pickup some 1333 Platinum @ CAS7 http://www.newegg.com/Product/Product.aspx?Item=N82E16820227478
Sorry I don't know much about RAM. The CAS7 is faster? What's the difference between 1066 and 1333? I don't know what these numbers mean, but I'm willing to learn
RIG #2
$415 (after $20 MIR)
RAM
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model OCZ3P1333LV4GK - Retail
$88.99
HDD
Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drives - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136284
$94.99
CASE
Antec Three Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Produ...lickDeals-_-NA-_-NA-_-NA&Item=N82E16811129042
$54.95
POWER SUPPLY
OCZ ModXStream Pro OCZ600MXSP 600W ATX12V V2.2 / EPS12V SLI Certified CrossFire Ready 80 PLUS Certified Modular Active PFC Power Supply compatible with core i7 - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341017
$54.99 (after $20 discount and $25 MIR)
CD/DVD BURNER
$33.99
GRAND TOTAL = $742.91!!!
