I have an Gigabyte Mother board with AMD X2(4600+) processor running at 2.4Ghz, Windows XP (SP3) and the following info:
Memory Type DDR2
Memory Size 4096 MBytes
Channels Dual
Memory Frequency 300.7 MHz (CPU/8)
CAS# latency (CL) 5.0
RAS# to CAS# delay (tRCD) 5
RAS# Precharge (tRP) 5
Cycle Time (tRAS) 15
Bank Cycle Time (tRC) 21
Command Rate (CR) 1T
the 4GB RAM setup is accomplished by the following two subcomponents from Transcend:
1) Max bandwidth PC2-6400 (400 MHz)
JEDEC timings table CL-tRCD-tRP-tRAS-tRC @ frequency
JEDEC #1 4.0-4-4-12-16 @ 266 MHz
JEDEC #2 5.0-5-5-15-20 @ 333 MHz
JEDEC #3 6.0-6-6-18-24 @ 400 MHz
2) Max bandwidth PC2-5300 (333 MHz)
JEDEC #1 3.0-3-3-9-12 @ 200 MHz
JEDEC #2 4.0-4-4-12-16 @ 266 MHz
JEDEC #3 5.0-5-5-15-20 @ 333 MHz
It is obvious that i purchased a wrong combination.. PC2-6400 & PC2-5300. I have the following questions:
A) What problems I might face.. or is it okay to run with this combo?.
B) When I run CPU-Z i get the following memory information :
I am sure i cant reach 400 Mhz, since one of the RAMs is PC2-5300. So how can I raise the memory frequency, and utilize atleast a speed of 333 Mhz?.
C) Or should i just do away with the PC2-5300 and replace it with a PC2-6400
D) I am also not sure hw to calculate the FSB and processor clock rate. Please help.
E) The mother board underclocks the RAM and on POST shows a speed of 667MHz. is it the same way the CPU uses it?
Thanks,
Krishna
Memory Type DDR2
Channels Dual
Thanks,
Krishna
