Cool thanks for that hafa!
Will give it a try... I've got a good feeling about this one since Safe mode works without a problem!!!
Just to confirm, i can 'disable' it, but still be able to use the plugs at the back of it to display right??
I guess since I have it on 2 seperate HDD, I can change the bios to load from a specific HD...
EDIT: I spoke too soon....... it froze on me as I was typing on my laptop :'(
Next option/step????
Hi guys... need a bit of help here.
I've been using winXP for a few years now, and thought I'll upgrade to win7.
Tried installing, and it either keeps freezing and/or screen loses connection (ie, flickers between analog/digital) and can't do anything but restart it.
I thought it was my HDD problem as it was playing up before, so I went to buy another one and same problem
I plugged back in my old HDD which I reinstalled winXP, and it's working fine without a problem.
Then I thought it was a temperature problem, but checked it and it's fine too.
Tried searching everywhere can't find an actual 'fix' for it
Any advice on what I should do next??
I read that it could be the a part on the motherboard not liking win7??
My computer:
Gigabyte GA-P35-DS3R
Intel Q6600
Corsair CM2X1024-6400
Nvidia 8600gt
Antec trupower 750W
Thanks for any help in advance!!
Since your memory passed, we can rule it out as the issue.
