Hey gang
So my last rig was on the exact same install disk as my new one now. Windows 10 pro 64bit. Did nothing different on the install. First thing I did was go into power setting and set it all up for max, nothing turns off nor sleeps. Adaptive brightness is off as well. Did a update on the graphics card and set a screen saver and now screen dims, but when i turn the rooms light on screen brightens. I have tried all the videos and tuts to get it off and still! I am at my wits end on this.
Old build
gigabyte board
amd hex core
gtx 760
New Build spec
MSI gaming pro carbon
i7 7820X
GTX 1080 Ti FTW3
all drivers are up to date, chipset, bios graphics and all small drivers as well audio etc. I even went in and disable the sensor monitoring. What do you think the issue could be? I have geforce experience installed but that should have nothing to do with it as i have it on all my work pc's.
My display is a samsung 40" seires 6 ultra 4k led tv, same as the old build.
Also getting a lot of flickering in on certain windows when moving the mouse.
Thoughts?
Thanks
Sevan
Old build
gigabyte board
amd hex core
gtx 760
New Build spec
i7 7820X
GTX 1080 Ti FTW3
Thoughts?
Thanks
Sevan
