- Mar 11, 2003
I accidentally clicked on the 'Do not show in this list" from the Windows 10 "Most Used" list. I have been searching for 2 weeks for an easy answer. That is an answer that doesn't involve reloading my OS. I just want to re-add the program that I removed. I thought just by using the program regularly it would reappear but it has not. Is there a registry setting or something? I have looked all over. Im here asking the experts on this one. I hope you all can help me fix this. I have tried the usual things as well. That is to disable and re-enable the Most Used list etc. No luck getting the program to reappear on the list. It just an annoyance more than anything but at the same time if I have to actually reload the OS to fix it then I won't bother. thanks in advance
Z
Z
