- Aug 17, 2002
Ok so I've purchased my first home and right now I'm typing this while sitting infront of my 60" TV on my HTPC using a wireless keyboard. I had a nice laptop with a few upgrades then it was ruined by baggage handlers of an airline. THe screen was busted but the machine still works.
Specs:
Intel i5 2.53ghz M460 CPU
8gb system memory
Nvidia m330 gpu with 1GB memory
256GB SSD HD
Overall I'd say it's a great machine. Right now it's running windows 7. My new laptop is a Windows 8 machine and after much use I think I'd rather fold it up and slam it against the wall until I simply couldn't anymore. Anyway I'm stuck with it.
Right now my older laptop is plugged into my Yamaha receiver via HDMI which then runs to my TV. I have a wireless keyboard that seems to be working just fine however I want to create a good media experience with the htpc and right now it's just my old main machine plugged into a 60" monitor.
What should I do to make this machine truely great as a HTPC? It just doesn't have that "IT" factor right now and feels more like someone trying to make something it isn't. Everything feels cumbersome. Should I reinstall windows 7 from scratch? Is there a different version of windows I should use besides 7 for this?
My goal is to put all my music on this machine, maybe plug in my external 1TB HD and put video's on it too, and be able to control it from my ipad. I just bought the plex Ipad program but don't think it's setup correctly since I can't use it as a remote.
So if you were starting from scratch with a perfectly capable PC what would you do? I don't want to select it on the receiver and people know it's a PC I'd rather it just be the front end and I can use my ipad to control it.
Also while trying to transfer over my music from my Windows 8 PC to my Windows 7 PC I'm only getting 1MB/s while on the same network. I'm pulling it from a shared folder too not using homegroups. Any idea why transfer speeds are so darn slow?
Thanks!
Duck
Specs:
8gb system memory
256GB SSD HD
Thanks!
Duck
