C:\Documents and Settings\Matt>fc /?
Compares two files or sets of files and displays the differences between
them
FC [/A] [/C] [/L] [/LBn] [/N] [/OFF[LINE]] [/T] [/U] [/W] [/nnnn]
[drive1:][path1]filename1 [drive2:][path2]filename2
FC /B [drive1:][path1]filename1 [drive2:][path2]filename2
/A Displays only first and last lines for each set of differences.
/B Performs a binary comparison.
/C Disregards the case of letters.
/L Compares files as ASCII text.
/LBn Sets the maximum consecutive mismatches to the specified
number of lines.
/N Displays the line numbers on an ASCII comparison.
/OFF[LINE] Do not skip files with offline attribute set.
/T Does not expand tabs to spaces.
/U Compare files as UNICODE text files.
/W Compresses white space (tabs and spaces) for comparison.
/nnnn Specifies the number of consecutive lines that must match
after a mismatch.
Specifies the first file or set of files to compare.
Specifies the second file or set of files to compare.
C:\Documents and Settings\Matt>comp /?
Compares the contents of two files or sets of files.
COMP [data1] [data2] [/D] [/A] [/L] [/N=number] [/C] [/OFF[LINE]]
data1 Specifies location and name(s) of first file(s) to compare.
data2 Specifies location and name(s) of second files to compare.
/D Displays differences in decimal format.
/A Displays differences in ASCII characters.
/L Displays line numbers for differences.
/N=number Compares only the first specified number of lines in each file.
/C Disregards case of ASCII letters when comparing files.
To compare sets of files, use wildcards in data1 and data2 parameters.
C:\Documents and Settings\Matt>sfc /?
Microsoft(R) Windows XP Windows File Checker Version 5.1
(C) 1999-2000 Microsoft Corp. All rights reserved
Scans all protected system files and replaces incorrect versions with correct Mi
crosoft versions.
SFC [/SCANNOW] [/SCANONCE] [/SCANBOOT] [/REVERT] [/PURGECACHE] [/CACHESIZE=x]
/SCANNOW Scans all protected system files immediately.
/SCANONCE Scans all protected system files once at the next boot.
/SCANBOOT Scans all protected system files at every boot.
/REVERT Return scan to default setting.
/PURGECACHE Purges the file cache.
/CACHESIZE=x Sets the file cache size.
