I am having worst temps in a I7700k@5ghz 1.30 volts between:
->KRAKEN X62 280 mm radiator -> 100% pump, 2 noctua fans PWM 14 IPCC 3000 INDUSTRIAL TO 100%. TEMPS:Idle 27 benching around 65.
->Waterextreme 3.0 120 mm radiator -> 100% pump, gentle thypoon 100%. Temps: Idle 25 benching max core 50 celsius degrees.
Other details:
Both push config TOP.
Case: Corsair Carbridge air 540
GPU 1080 ti FE sending air out the case
Thermal compound Gelid Extreme in both cases.
Reinstalled the x62 two times and same temps...
Other details:
