- Jul 31, 2005
http://www.xyzcomputing.com/index.php?option=content&task=view&id=810
SyncMaster 305T
Panel
Viewable area: 30"
Pixel pitch(mm): 0.250 x 0.250
Brightness (typ.):400 cd/m2
Contrast Ratio (typ.): 1000:1
Viewing Angle(H/V): 178 degrees / 178 degrees
Response Time (ms) (typ.):6 (GTG)
Frequency
Horizontal Frequency(kHz): 30~81
Vertical Frequency (Hz): 56~75
Maximum Resolution: 2560 x 1600 at 60Hz (Digital)
Color Supported: 16.7 Mil.
Signal Input
Input Video Signal: Dual DVI Digital Link
Sync Type :Separate H/V
Input Connectors: DVI-D (Dual link)
-Plug & Play
- DDC 2B
- USB powered hub option
- USB 2.0 (1 up x 4 down)
- Mac Compatibility
Power
On Mode: 130 Watts
DPMS Mode: <2W
Set(W*H*D)(mm) (with Stand): 690.2 x 502.0 x 280.0
Set(W*H*D)(mm) (w/o Stand): 690.2 x 449.6 x 83.0
i say altho its a little more pricey, its a very good alternative.
SyncMaster 305T
Panel
Viewable area: 30"
Frequency
Signal Input
-Plug & Play
- DDC 2B
- Mac Compatibility
Power
On Mode: 130 Watts
DPMS Mode: <2W
