I just replaced the core of my X2 4800+ S939 system with the components listed in my sig below.
I tried the quad-core unlock just for kicks (I really don't need an X4, if I did I would have bought one) and I get checksum errors in either X4 or X3 modes. In X3 mode I even tried both core 3 and 4, still no go. I assume that as long as the mobo support ACC (in this case Bio-Unlocking...) the issue is the CPU and not the mobo? For example, this CPU probably has 2 dead cores and a DFI or Asus mobo will not make a difference?
Secondly, I am currently using the stock HSF, I was planning on using my Thermalright XP-120, however, the mounting bracket does not fit on this board. I also have an older all copper Thermaltake Volcano 12, it seems quite a bit larger than the stock HSF and since it is all copper, it should dissapate the heat better. Should I swap that HSF into the machine?
Finally, from what I have read the 555 BE is a nice oc'er, what kind of clockspeed should I shoot for with either the stock HSF or the Volcano 12? I have seen some at 4+ Ghz, however, I am quite sure they are using some exotic cooling.
Thanks!
Thanks!
