- Jan 18, 2012
hi guys,
i bought my pc a week ago and thought id get something i could play some pc games on. decided id need better card than came with the pc so decided on the xfx hd 6950 xxx 1gb.
my specs are this:
Gigabyte GA-880GM-USB3 main board
AMD FX-8120 Eight Core Processor, 2812 Mhz
1tb toshiba hdd
Alpine 600W Gold Fan
16GB 1333mhz Mustang
Windows 7 Ultimate x64
so the problem is, i had the sapphire hd 6450 installed in my pc when it arrived and that worked fine in the pc, 2 days later my xfx graphics arrived, i thought it would be a simple case of remove the old drivers, put the new card in and install drivers, iv tried using driver sweeper, removing the graphics drivers of the xfx card through safe mode etc. but the problem is that the card basically refuses to work.
as soon as i login it is ok for a couple seconds then even clicking on something in windows or moving the mouse causes the screen to flash black with green interference then the amd graphics driver fails. sometimes it can recover other times iv had to press reset button just to get the pc working again, this is a brand new pc with brand new hardware from a brand new installation and i cant seem to get it working atall.
anyone got any ideas whatsoever may have caused it, or any idea on how to fix this problem, also iv tried the latest version of drivers and also numerous older versions including drivers from 2010 just incase it was a compatibility problem with latest drivers. still getting driver crashes. iv spent nearly £1000 on accessories and various components to make this pc great, just need to get it working to its full potential.
my specs are this:
1tb toshiba hdd
