Contend_Gewz
- Aug 10, 2014
Hey guys.
First of all, thanks for all the knowledge I've gathered on here. I've noticed that when searching on google, this forum usually comes up with the most helpful answers!
Anyway,
I have the Cooler Master HAF XB cabinet, hooked up with two radiators. 1 x 240 in the front, and 1 x 120 in the back. The resevoir is an XSPC X2O 750 Dual Bay Reservoir Pump V4, placed in the 5.25 slots.
The loop is as follows:
Resevoir/pump -> GFX -> CPU -> RAD -> RAD - Resevoir.
The issue is, that I have one very large bubble in the loop constantly. It's moving around, depending on how I twist and turn the cabinet, but it usually flows back to loop between the CPU and RAD(Which is the highest point in the loop).
Given the design of the cabinet, the Resevoir is always the lowest point in the loop, hindering the air to reach the resevoir by itself.
I have experienced some performance issues(not bad temps per say).
Do you have any suggestions as to how I can remove the bubble? Turning it upside down etc. has been tried, and has removed some of the air, but I can't have the resevoir open while I do that, for obvious reasons.
Thanks in advance!
Anyway,
Thanks in advance!
