- Nov 28, 2003
- Appleton, Wisconsin
I'm currently in posession of my uncle's old A7V266-E Rev 1.06 motherboard. He just upgraded to a Athlon 64 system because this one was causing problems.
I think I have it solved, though. But I want a second (or third or fourth or etc...) opinion. I found that a stick of RAM was bad when I put it in my computer. It kept corrupting Windows. Needless to say, that stick is garbage and no longer used. I had it in my NF7-S, and I would get errors about ntfs.sys being corrupt, and all that good stuff.
However, my uncle said when he would have the computer go into an endless reboot cycle, no errors or anything. Before he upgraded, we decided it was probably a bad IDE controller. I don't think thats right, though.
Right now, I have it set up in my basement with a good stick of RAM, and XP Pro running just fine. I have Prime95 running a tourcher test on it. Nothing bad has come up yet.
Do you think it was just the RAM that screwed it up? Also, are there any other programs like Prime95 that will push the board to its limits? I use 3DMark01, and SANDRA burn-in wizard. Is there anything else I could use? I mainly want to make sure the IDE controller is good. If it is, then the problem was the RAM.
