- Oct 15, 2001
- Tennessee
Are there any 100 Base T network cards that run at 66 MHz? I ask because I am building a new file server and I want the NIC to be on the 66 MHz PCI bus, to avoid latency issues associated with the 33 MHz PCI bus, but I don't want it running at 33 MHz, because that would slow down the bus and I have a 66 MHz SCSI RAID card in the other 66 MHz slot.
This is all on a 760MPX motherboard, BTW.
I believe there are Gigabit Ethernet cards that run off 66 MHz, but are they backwards compatible with 100 Base T networks?
I know this is the SMP forum and not Networking, but I figured you SMP folks probably have a lot more relevant experiece with this issue.
Thanks.
Thanks.
