need to split up inlet water line to cpu waterblock, northbride waterblock and videocard waterblock. don't like the fact that my cool water has to go thru the cpu then nb and then the videocard. currently using a eheim 1048. any ideas. is there like a 3 way split fitting that i can use. also would like to use either 1/2 id water line or 3/8 id water line. here is a diagram of what i have now.
pump---cpu inlet---cpuoutlet---nbinlet---nboutlet---videoinlet---videooutlet---radi---pump.
this is what i would like to do
cpu inlet cpu outlet
pump-----nb inlet nb outlet --- radi---pump
video inlet video outlet
thanks
thanks
